Root Linux user here - stuck with "insufficient permissions for device"
Rene.
The phone is correctly rooted, and I'm using this method:
FASTFORWARD TO 5:17 PLEASE :)
YouTube - How To Root & Sideload Apps on the Samsung Captivate with Windows
I get stuck here trying to install a HTC_IME.apk file (trying to get the HTC Keyboard on my Cap) to my phone. I've ran it as a regular user and as a su user in my terminal. Is this an error on my phone's end? Maybe I missed a setting during/after rooting my phone?
Code:
rene@rene:~/Android SDK /android-sdk-linux_86/tools$ sudo ./adb install HTC_IME.apk
[sudo] password for rene:
error: insufficient permissions for device
Help would be greatly appreciated :D
maerlim's guide did not look linux friendly (few things are different in the linux terminal than the windows command prompt) which is why I haven't tried it, but if any other linux users followed his directions I'll try to give it a go.
*******EDIT*******
Ok so I ran ./adb devices to view my device just for the hell of it and here's what returned:
Code:
rene@rene:~/Android SDK /android-sdk-linux_86/tools$ ./adb devices
List of devices attached
????????????    no permissions
My phone is mounted correctly, USB debugging is on, what the heck did I miss? :( From what I can gather it probably does not even detect my device :(
sudo ./adb kill-server
sudo ./adb devices (it should no longer say ????????????? no perms)
sudo ./adb install <name of app>
if the install command doesn't work:
./adb push <name of app> /sdcard
install from the phone using Astro or, my favorite, EStrongs.
thanks so much, your solution fixed my problem (sudo ./adb devices returned
It makes sense now because the first time I ran adb it wasn't as sudo, so the deamon started with insufficient privileges. "sudo ./adb kill-server" and then starting adb as sudo did the trick!
