brocja01
I'm assuming I need the Kernel that are on the left of the arrow? Not the 1.5 Kernels correct?
Could someone possibly answer this? Looking to run a 1k on my phone, want to make sure I download the right one.
Thanks!
Thanks!
I hear what your saying, but the ROM wasn't "really" changed. LFY was added to ROM Manager and the "change" to the ROM was just a text only change which was enough to make the MD5 checksums return different values when trying to verify the files
The people who have seen their temperature "problems" fixed...is a coincidence or perhaps a result of re-flashing the ROM.![]()
i flashed the LFY rom and got that running. do i need to download the kernel and flash the kernel as well? same thing for themes, download and flash?
I am also using LauncherPro, and getting horrible lags
I may go back to BB4
This ain't working too well right now. I will use ADW for a little bit see if it helps though
Issue isn't where they are, is which one to grab. There are two different versions on kernels, and I've been reading that some kernels break something and the others don't.On the first page ( liquid slayher kernals) u can get them
I tried this as well, and my battery didn't like it. I keep it at minimum 300, max 1200 and it works just fine on interactive.
I've never had the issue and mine is set to 125mhz for the screen off.
I went into the build.prop file, edited the text for call delay
from 1000 to 500. It made a difference on my phone.
So I'm asking which ones I can grab.
i had a lotta lag with launcherpro. i switched to adw and i am not seeing any lag now. funny adw works better on this rom for me but launcher pro works better than adw on most other roms.
I know one way to find out! LOLIve got the 1.5 1200 that is near the bottom, I didn't realize others had come out. I'm tempted to try the 1300 but I can't imagine that would be stable.
How are you guys setting your speeds at those 125 and 300 for minimum? Set CPU is only showing me the option for 250 at the low end and 400 the next lowest.
the kernal you are using determines the speeds you can adjust your phone to by its set slots. slots are set speeds your phone can run at. your 250 is the lowest slot 400 is next. if you want to have a lower first slot you should download another kernal.
ok. I guess I just assumed they were getting those on Slayher's LFY kernels, but apparently not then?
I'm running the 1100 Slayher kernel for 1.5.
perhaps so i think slayher has kernals with mixed slots. they may be running a different version.
Well the test of the 1300 was a disaster. Crashed everything.
Try the 1000 slayher you won't be disappointed![]()
How do you do this?
