GirLuvsDroid
Android Expert
ahh cool! what's compcache though?![]()
Take a look here: Froyo Kernels by slayher - CyanogenMod Forum - Page 5 (scroll down to post #91).
These slayher kernels are a result of a collaboration between Liquid and slayher. They fix Goggles AND (drum roll) have compcache enabled by default.
Really? So you mean there is a built in script that
turns on compcache when the phone reboots?
The kernels on the index page say v1.5?
Are they the latest with the new wifi module?
Just want to make sure, downloading now, flashing in a few!!!!!
THANK YOU LIQUID, LIQUID GurL and the entire testing team!!!!!!!
do we have to run compache in terminal?
they say 1.5 for lfy 1.5, not for slayher version. And yes, they enable compcache automatically after each reboot (i tested this functionality multiple times last night).
Nope, you don't have to run anything in terminal to enable compcache -- it's built into the rom.
How Do I Install The smoked theme to my phone?????
what is this "stagefright" fix all about?
Just download the theme (.zip file) and then flash it like you would a ROM (but DO NOT wipe data/cache or anything like that).
The stage fright fix is built into the source and is not the build.prop hack you are thinking of and will not effect your quadrants scores like the hack doesstage fright is the streaming media decoder that apps like Pandora use to stream music to your droid.
How can i reinstall launcher pro after I have uninstalled it? I keep trying but it errors out every time.
Question for you.
Did you install LFY 1.5?
If so how did you uninstall Launcher pro since it
was made a system app in this version (according to the log) ?
You can do it using the scripts and a terminal emulator.
O-I-C.
Shouldn't there be a script to push it back to system/app?
