morgan_allstar
argh! not sure if this is a LFY issue or not, but i can receive emails thru the gmail app but they get stuck in the outbox when trying to send them. any suggestions?
Thanks yankee yes we did recieve urs and urs were last we recieved my time spidey senses must be off lol
I'm testing v1.8b now -- you won't be disappointed, guys!!
Give us some tidbitz...
Will we be able to disable compcache? I went through your tutorial but am not sure if I got it so I thought I would just wait for the new release. Still the best overall package of rom, themes, and kernels.
I don't think Liquid will be mad if I reveal that compcache is disabled by default in v1.8, but is easily enabled in Liquid Tweaks.
By the way, you can tell if compcache is turned off (by using my tutorial) in v1.7 by going into Terminal Emulator and typing:
su
/system/bin/compcache stats
If it tells you "Failed to open /dev/block/ramzswap0: No such file or directory" then compcache is off. If it comes back with a bunch of lines with numbers (the top of which has Disk Size in excess of 57k), then compcache is still on.
Gee thanks GLD for ruining the suprise lol jk still love ya![]()
anyone else have a messed up Calendar widget? Mine is just transparent black with black writing, so its very hard to see..
This is from a fresh install doing all the necessary wipes.
What calendar widget are you using?Bump?![]()
I use the built-in calendar widget and it shows white on black using LFY 1.71 and the Blueberry theme.Bump?![]()
Bump?![]()
I have had a problem sometimes switching between roms where the background on my CalWidget would be gone and I could not see the text. I pulled it down and removed it and then put it back up and it was fine.
