Root Liquid Rom 3.2 on Droid X Gone Wrong HELP!
I installed liquid rom 3.2 on my droid x, i had it rooted and i had liquid on it previously so i go to install the newer version in the boot menu and i select to load it off my SD card.
it installs fine and says it finished so i hit reboot & it now gets locked on the motorola M logo
I have tryied holding home > power > search > and then got into the restore menu back to factory
That loads and then I hit restart after its finished and I dont think it worked since it continues to remain locked on the M logo
Any ideas?
Did you wipe data before installing it as per the instructions? Might be worth a try before going the SBF route.
I went stupid and tried to just load liquid gingerbread 3.1 to mine with wiping my data first and it was stuck until I got into manual clockworkmod and wiped it a couple of times and reinstalled it and it worked
