Root Liquid ROM HATES my SD Card
Addicted
Member
As the title states, I have(or had rather) Liquid Smooth ROM on my phone, Today it decides that it's not going to let me use my sd card anymore. No gallery, apps on the SD card wont run... Went back to CM7 but I really do like the Liquid ROM. Anyone suffer similar issues?
im having problem with apps on my sd card but ive got gallery and most other common apps with no problems. it just lately happened even tho ive had liquid since it came out. The only difference i can think of is that im using aerovan kernal. Anyone else?
My apps were messed up until I stopped installing them externally. Installing them internally and then moving them they were fine. I really don't want to use liquid if it's going to jack up my gallery. the downloads in particular. Seemed as though when i used firefox and saved a video is when it started.
DAMMIT! It did it again! Works awesome for a week, then if I have to do anything that involves my SD card it shows that it's unmounted after I stop using it. What the hell! I guess I'll stay on CM7.
