Root *+*+*LIQUIDSMOOTHv2.1.4 rom+*+*
andriodadmirer
LIQUID*********SMOOTH
VERSION 4.1.2 jellybean
FIRST OFF THIS WAS NOT BUILT FROM SOURCE, THIS WAS MADE POSSIBLE FROM A SKELETON BASE OF PLAYFULGODS CM10 SO, OF COURSE WITHOUT HIS WORK NONE OF THIS WOULD BE...
SO THANKS TO YOU PLAYFULGOD FOR ALL YOU HAVE DONE FOR THE MOTION COMMUNITY
LIQUIDSMOOTH v 4.1.2 jellybean
WHAT IS THIS?
LiquidSmooth is an aftermarket firmware based on the Android Open Source Project.
providing Android users with smooth, stable and fast Roms
it is an open source project. Please feel free to look at our code on LiquidSmooth GitHub
We would like to thank CyanogenMod for their device trees, framework/settings mods and their code that was incorporated into this project.
Furthermore, we also extend our gratitude to AOKP, Team CNA and Team EOS for parts of their code that we have incorporated.
Henceforth, all downloads will be available via our new website -
LiquidSmooth
Changelogs will also be posted there.
Liquid smooth team:
Liquid0624
Liquidzgrl
Nocoast
Hiemanshu
ToxicThunder
RaymanFX
DaGr8
DG4Prez
Features:
Comprehensive speed enhancements
Customizable lockscreen buttons and sliders
Customizable hardware and software keys
Transparent navbar and status bar
Customizable navbar ring
Navigation bar widgets
Customizable power menu
Notification power widget
Customizable quicksettings panel
Statusbar mods
Theme engine
Quiet hours
Volume rocker music controls
Full Rotation
Customizable battery and notification light
i also am including the newest 4.3 gapps pulled from the NEXUS 7
everything works i have screen shots here of them on my own phone
******** KNOWN BUGS*********
before tou flash gapps go into the rom and sign into the playstore first
the rom may tell you that you need google play services to use the gapps just go to playstore and update/and or dowwnload it and it will work
also the nav bar will be on when you flash the rom so to turn it off, go to settings then liquid splash then to nav bar settings disable it but then reboot your phone otherwise it will pop back on
other than that please let this post know what else is not up to par
here's the rom....
http://db.tt/gVI0GKCL
here's the gapps
http://db.tt/G56JkNN0
lNSTALLATION
do a full wipe factory reset, data, cache
go to advanced and wipe
dalvic cache
then mounts and storage
format
system
then navigate to install from sd
find liquidsmooth
install and your done
here are some screen shots
http://s1346.photobucket.com/albums/p683/Andriodadmirer
Ok.. I'm on the rom right now. First I like the boot animation a lot, I like having different types of settings within the actual settings like you guys added. So far only had one quick soft reboot (boot animation and back to desktop). Google apps are force closing every other few minutes. I can't get rid of the tablet navigation bar it just re opens on its own. Wifi works, not sure about BT yet.. or gps and call volume since I have no service right now. Other than that it does seems like a smooth rom. +++ for an extra rom on our motions :)
Edit: looks like play store is more stable now after flashing the gapps package you provided. And also navigation bar problem is fixed, I had forgoten to reboot right after.
Edit: Well I guess play store force closes still persist, and there is an obvious random reboot issue. Still smooth rom.
Ok.. I'm on the rom right now. First I like the boot animation a lot, I like having different types of settings within the actual settings like you guys added. So far only had one quick soft reboot (boot animation and back to desktop). Google apps are force closing every other few minutes. I can't get rid of the tablet navigation bar it just re opens on its own. Wifi works, not sure about BT yet.. or gps since I have no service right now. Other than that it does seems like a smooth rom. +++ for an extra rom on our motions :)
Camera???
OK for service toggle your airplane mode on and off and it will cone back
Call volume is average
Also DONT install gapps without first going into the ROM and sign into play store the reason the gapps force close is because your play services is not updated
If the gapps make you weary then maybe stick to the 4.1.2 gapps
Remember to flash gapps after you log into play store and let it update
The Navy bar has to be toggled off then you reboot right after
I did all mentioned, and about service I really do have no service, I purposely havent payed my bill yet lol.
Side note: Kik is having the same forceclose issue that it was having on pg's latest rom. Also I have noticed all these cm10 roms being made are not letting instagram record videos with the new feat. U press the button , it begins to record and as soon as u let go it goes back to zero like u never recorded anything.
The nav bar problem can be fixed by simply turning it off on off in the settings and rebooting. Also another bug I want to point out is that you can't change the default keyboard since it force closes
that same solution you mentioned for the navbar can be applied to choosing a different keyboard, im using swiftkey atm, before it worked I had to disable aosp keyboard-then select swift as default, reboots it self then works normally
all LWP work except microbes, whch imo is the best oneeeee
seems like actual hardware keys backlight doesn't turn off-- now they wont turn on lol, seems to vary between the two after reboots
I also have the hardware key backlight issue. Doesn't appear to be a setting for them, either. When I open Google Maps, I get "Google Text-To-Speech engine" crashes, repeatedly.
great stuff, there are a few things I cant figure, if MMS is working or not, I cant tell if it's just my signal atm or what, I have not saw the 4g icon yet only 1x-3g and im not sure if its just stating it incorrectly when it is infact 4g ( I don't have signal to test atm till I go into the city)
things I've noticed that are the same with pg's build
KIK messenger still FC's on initial load, beautiful widgets weather theme picker fails aswell, you can select download theme and it'll just be downloading forever, call volume still fairly low but easily useable.
other than that and the key light issue, butter ;)
the screen backlight turning on when you power off the screen isn't present^^
the screen backlight turning on when you power off the screen isn't an issue
The 1x icon actually represents 4g.
All the problems that were on pg's build are carried on this.
You might be able to fix mms by simply downloading the inverted mms
I think it's in the motion toolkit.
