little help
I think it is a default notification sound. I cannot be sure though.
You may be able to change it by pressing the Menu button while you are in the voicemail app. I actually changed the sound of my text message notifications to something different, so I left the voicemail notification sound the same as it was originally.
With voicemail open, hit menu then settings. Then go to notifications, you can change the sounds.
when i download it a notication sound from mobilo it also changed the voice mail without me doing anything.
