Help Little Photo app problem
kevinrubio
Android Expert
so i downloaded the app after seeing a nice review about it, i saw how you could edit pictures really good so i wanted that, so i started up the app and clicked on the camera picture, and took a picture of something and than waited, A little pop up screen came up saying if i should "Force close or wait" so i hit wait, and nothing happened, the thing popped up again, so i hit force close and then i try to do it again, and it now says cannot connect to camera, also it says that with the stock camera too.But as i had alot of experience with my ascend i rebooted my phone so my camera could work again, and it did. So is anybody else have this problem? Cause i want "little photo" app working on my phone but it won't let me.
Just a quick heads up. If you are on CM7 (AFAIK)...no apps will work with the ascend camera. It is a VERY crappy camera. Your best bet (probably) is to take the pics and transfer them to your comp and edit them that way.
that sucks :(
To get the camera to work again you need to reboot your phone. If you use that app the same thing will probably happen again.
