Will the TPU case still work with it?
Wonder if it works with the Otterbox Defender?
Does anyone know if this extended battery fits/works with the "Standard Battery Charger w/Stand, Battery & Y-Cable"?
Set Your Location
I was thinking about getting the extended battery so I followed this link to the Verizon site, but for me it is only showing the discounted price of 35% off that I believe is part of my work discount that I would get on all accessories.![]()
Try again after logging out of your account.
It comes with a new cover but I can't tell a difference between them.
will the incipio double case fit the extended battery?
I just edited my previous post after trying that. No luck. Thanks.
Yes it was in a Corporate Store.
Showing up as $37.49 for me. I'll keep checking...
See my post above... like 2 or 3.
VZW corp (normal vzw stores) said they had it 50% off in their system already, so I ordered there, shipped to my work.
Did you call your local VZW store? They can do the SAME EXACT ORDER... I'll bet a call to 611 could do the same thing, but just sharing my story bro!![]()
Got it. And GOT IT.
I had to log out of my account because my corporate 25% discount was over-riding the 50% discount. Finally got there.
Thanks, and thanks to the OP.
Probably was, I was on the phone too, trying to pretend to be interested in the conversation, so, I most likely missed it. Thanks again. I was very close to asking for one yesterday. Glad I waited.
Does anyone else miss the long press to change input methods. I find it mildly annoying that I have to go inti settings to switch from swiftkey to standard keyboard.
On a positive note I don't miss my track pad as much as I figured I would.
