Root Live Wallpaper?
BankZ
I installed a new ROM (TranQuility) and it deleted all my live wallpapers. Is there a way I can get these from a backup an install them in the ROM?
Nothing wrong with backup up with Titanium (or any other app), you just have to be careful what you restore with any app.
Many people in this forum think Titanium is one of the best.
Sure you can copy, but then you have to worry about file and folder permissions. Where are you going to copy them from?
I have back up images I can restore. If I used TB what do I have to back up? What's it called?
Create a recovery image of your current setup.
Restore a previous recovery image with wallpapers, then install Titanium, open it and tap scheduler and run either backup.
When it finishes, find your wallpapers under backup/restore and make sure they backed up.
Reload your Tranq backup from recovery, install Titanium, then restore your wallpaper under backup/restore. If you decide you like Titanium, tap schedule and check one of the scheduled items that matches your needs. The free version will only keep your latest backup.
