My apologies, I believe i've posted something about this previously but i was never able to make it happen. Is there any way I can run live wallpapers on plain jane???
Just flash this zip through recovery and switch your "home" to the nexus launcher then press and hold anywhere on the screen and pick wallpaper then live wallpaper and choose a wallpaper.
Download: zifnab-mod-v2-signed.zip
You didn't break it all you have to do is clear the default home setting. Download clear defaults from the market use it and then press home and choose sense as your default and you will have sense again.
Right on, i was just about to type "I meant UI" but know what I meant. Right on bro, Thank you so much! Can you recommend some good LWP's that run well on eris?
