mount -o remount,rw -t yaffs2 /dev/block/mtdblock3 /system
Use Android Commander to install the files.
Android Commander
Connect Phone via USB.
In Android Commander, click on Console tab (bottom left) and
Cut and Paste this line into shell command to enable r/w access.
Now go to Commander Tab and copy over files. Remember to [x] the file to copy it.Code:mount -o remount,rw -t yaffs2 /dev/block/mtdblock3 /system
Paths as follows:-
/system/app
LiveWallpapers.apk
LiveWallpapersPicker.apk
VisualizationWallpapers.apk
/system/lib
libRS.so
librs_jni.so
@ Beerkan -> in a previous post where you detail how to upgrade the Spica to 2.1 and root, you mentioned that Livewallpapers.zip can be uploaded via the recovery Menu... Can this be done with the Livewallpapers.rar you posted in #6 of this post?
