Help Live wallpapers
Country Dad
OK, so I rooted my samsung admire, Remove the metro crap (also remove some things I needed, but learn from this site how to add them back on now that I have a file with all the apps that came on the phone) anyways, so Im looking at the live wallpapers, is there a way to remove the wall papers that came on the phone, I cannot remove this app from the phone cause then live papers will not work, I just want to remove the stupid ones that came with the phone. Thanks
As far as I know you would need to edit the "livewallpaper picker" app
is there another livewallpaper app I could download to replace the stock one? or is it the wall paper picker that holds the useless wallpapers?
if you want to remove install super manager and delete them.. dont know the exact folder but it dont take long to navigate through all the folders :D
does anyone have the factory apk for live wallpaper and mms...i deleted mine by mistake and now i cant use either feature
I use Live wallpaper maker by KNU Apps... The reason why i love this app is because it allow the user to customize which images load as wallpapers. you can set a specific folder duration and you can even change which image is currently on display by double tapping the screen....
I
Use my SYSTEM DUMP and pull/push that file to your system/app ..
need help with that just pm me and I'll explain how to...
I have all the aps for The samsung admire, if you need something Pm me, and I will get it over to you. You can also search this forum, someone posted a link for all the app to the samsung admire, that is where I got it form.
