Root Loading (solved)
reaply
How long does it take to install a ROM?
I have recently downloaded and I am currently trying to install a ROM.
CM7 Newest GB rom by Reppard
I put it into the 000root folder, turned off the phone, went into the recovery screen and I installed the zip folder so I rebooted my phone. And then it loads a screen with an icy circle around the android mascot. But it froze. Is this normal?
(solved)
