Loads of duplicate contacts
Ok so I accidentally imported my sim card contacts into my phone twice. Now while I have hidden the sim card contacts so everything looks ok on the people screen, if i go into a contact and look at what it is linked to there is 3 versions of the contact all on the phone and all just with the number.
Is there an easy way to sort this out?
Or should I just delete all my phone contacts and import from sim again?
Ok think What I will do is Sync my contact with google. Sort them all out then resync. Then I will sync with microsoft outlook so I have a "hard" copy so to speak then delete all phone and sim contacts and then sync with outlook and google again. That way I will have the google contacts all merged with the phone contacts. Going to be fun as I'll then have to go through all the contacts and link with facebook contacts!
I usually sync with Outlook 2007 on my desktop but i have the 2010 beta on my laptop and for some reason it doesn't want to sync at all. Says i have no mail program installed. anyway to fix this?
