System ui. In settings/app
i see it now, ty.I see it in framework res drawable hdpi
"stat_sys_gps_privacy.png"
ya but for some reason i dont have a values folder in the framework-res, so i cant edit the array.xml. im on #2 2.7Np, I knew I seen it somewhere LOL.
ya i ended up doing that, had trouble recompiling but i think i gotWhat you want to do is move the gps all the way to the left using my guide to rearrange icons on the ATR, then replace the gps png with a clear png
i got backups for daysIf you just delete it it will give you the same effect. At least it did for me.
@op Just make a backup first![]()
deleting the png will just leave a blank spot, plus i like the center clock mod also.
i know its blasphemy but im kinda going for the iphone status bar..moving signal bars all the way to left, battery on right, might change the location icon to something that just has my name or "mpcs"
i just like the status bar to look clean, i hate when it gets cluttered up with all these different sized icons
