I'm running an older version of PAC ROM with Haunted Kernel. I've been on this build for awhile without issue.
I don't have this all tacked down, yet, but I've been experiencing odd boot loops from out of nowhere for the last 2-3 weeks. The device is completely unreliable - even when it wakes, apps will not update and some are simply inaccessible. Issues started random and got worse [or so it seems]. I haven't noticed a specific pattern, only that sometimes the phone works perfectly...others, the screen is off and won't turn back on. The device lights up, but no screen action. Simulating a battery pull does nothing. There is no way to get into Recovery.
The device boot loops in two different ways. the first is like a power issue. No charging lights and the phone sits there buzzing every 20 seconds like it wants to start up, but cannot.
The only way I've been able to get the device out of this state has been to plug it in and out of a power supply - sometimes, when I'm lucky, the screen will light up and the phone will work. The device is not recognized in ADB, so I can't use the command prompt to interact with it.
The last time I got the phone screen to come on, it was boot looping the Welcome screen. I immediately dove into Recovery to find there was no storage recognized...so, no ability to restore back ups. I was able to boot directly into the phone from there without issue.
I did notice Goo was prompting me for a ROM update prior to these issues. I'm curious if somehow the ROM was updated via Goo without my interaction. It seems unlikely, but the issue kinda stinks of a botched update.
Snooping around the various forums, I'm seeing people report devices working perfectly, then displaying these symptoms, so I thought I'd share my experiences.
If I can get the device to wake up again, I might play with kernel settings to see if it helps. If I am able to identify a root cause or fix, I'll circle back to share.
Three.
