ac4android
I am trying to instantiate an instance of LocationManager, the objective is to run locationmanager.reueqtsLocationUpdates() inside a handler later on.
I am running this tethered to my Android smartphone indoor. Might that be a problem because I cannot get a GPS indoor?
Have I missed something in the manifest, perhaps ?
I've been working on this for a while, so any help would be appreciated.
Manifest follows:
This is my module's build.gradle, I have commented out " compile 'com.google.android.gms
lay-services:9.2.1' " because I don't want to use it for now:
This is the output from debugger, the null object reference seems to be my LocationManager
this = {MainActivity@4389}
view = {Button@4392} "android.widget.Button{7f7e97f VFED..C.. ...P.... 828,255-1092,399 #7f0c006e app:id/start_button}"
ex = {NullPointerException@4445} "java.lang.NullPointerException: Attempt to invoke virtual method 'java.lang.Object android.content.Context.getSystemService(java.lang.String)' on a null object reference"
running = false
Manifest follows:
Code:
<?xml version="1.0" encoding="utf-8"?>
<manifest xmlns:android="http://schemas.android.com/apk/res/android"
package="com.example.testhandler">
<uses-permission android:name="android.permission.INTERNET" />
<uses-permission android:name="android.permission.ACCESS_NETWORK_STATE"/>
<uses-permission android:name="android.permission.ACCESS_FINE_LOCATION"></uses-permission>
<application
android:allowBackup="true"
android:icon="@mipmap/ic_launcher"
android:label="@string/app_name"
android:supportsRtl="true"
android:theme="@style/AppTheme">
<activity
android:name=".MainActivity"
android:theme="@style/AppTheme.NoActionBar">
<intent-filter>
<action android:name="android.intent.action.MAIN" />
<category android:name="android.intent.category.LAUNCHER" />
</intent-filter>
</activity>
</application>
</manifest>
Code:
apply plugin: 'com.android.application'
android {
compileSdkVersion 23
buildToolsVersion "23.0.3"
defaultConfig {
applicationId "com.example.testhandler"
minSdkVersion 17
targetSdkVersion 22
versionCode 1
versionName "1.0"
// Enabling multidex support.
multiDexEnabled true
buildTypes {
release {
minifyEnabled false
proguardFiles getDefaultProguardFile('proguard-android.txt'), 'proguard-rules.pro'
dependencies {
compile fileTree(dir: 'libs', include: ['*.jar'])
testCompile 'junit:junit:4.12'
compile 'com.android.support:appcompat-v7:23.4.0'
compile 'com.android.support:design:23.4.0'
// compile 'com.google.android.gms:play-services:9.2.1'
Code:
// tidied up codes
import android.content.Context;
import android.os.Bundle;
import android.os.Handler;
import android.util.Log;
import android.view.View;
import android.app.Activity;
import android.widget.TextView;
import android.widget.Toast;
import android.location.Location;
// import com.google.android.gms.location.LocationListener;
import android.location.LocationListener;
import android.location.LocationManager;
public class MainActivity extends Activity implements LocationListener {
private Context context;
private double dd = 0.0;
private boolean running;
private static final String TAG = "ACDebug";
LocationManager locationmanager;
Location location;
Boolean canGetLocation = false;
Boolean gpsEnabled = false;
Boolean networkEnabled = false;
Double dlatitude, dlongitude;
String latitude, longitude;
@Override
setContentView(R.layout.activity_main);
@Override
protected void onPause(){
super.onPause();
running = false;
@Override
protected void onResume(){
super.onResume();
public void onClickStart(View view){
// test availability of LocationManager first before diving in!
// Put this codes in runLocTimer()
running = true;
runLocTimer();
public void onClickStop(View view){
running = false;
public void onClickReset(View view){
running = false;
private void runLocTimer() {
final TextView sysmsgview = (TextView) findViewById(R.id.sysmsg_view);
final TextView latitudeview = (TextView) findViewById(R.id.latitude_view);
final TextView longitudeview = (TextView) findViewById(R.id.longitude_view);
try {
locationmanager = (LocationManager) context.getSystemService(LOCATION_SERVICE);
gpsEnabled = locationmanager.isProviderEnabled(LocationManager.GPS_PROVIDER);
networkEnabled = locationmanager.isProviderEnabled(LocationManager.NETWORK_PROVIDER);
if (!gpsEnabled && !networkEnabled) {
// No point in running the runLocTimer()
running = false;
} else {
Toast.makeText(getApplicationContext(),
"gpsEnabled : networkEnabled = "+Boolean.toString(gpsEnabled)+" : " + Boolean.toString(networkEnabled),
Toast.LENGTH_LONG).show();
// if we have GPS signal
final Handler handler = new Handler();
handler.post(new Runnable() {
@Override
public void run() {
//TODO
String slat = String.valueOf(dd);
sysmsgview.setText(slat);
latitudeview.setText(latitude);
longitudeview.setText(longitude);
if(running){
dd++;
handler.postDelayed(this, 1000);
} catch (Exception ex) {
ex.printStackTrace();
@Override
public void onLocationChanged(Location location) {
//TODO
@Override
public void onStatusChanged(String provider, int status, Bundle extras) {
//TODO
@Override
public void onProviderDisabled(String provider) {
// TODO
@Override
public void onProviderEnabled(String provider) {
// TODO
} // END of MainActivity
running = false
