Help lock bot pro issue - double screen [resolved]
Using Lock Bot Pro on my Eris with v2.1. When I press to open the phone - the Lock Bot screen comes up in a faded view then disappears and I have to press open again. I think this is described as a "double lock screen" issue?
Anyone got a fix? I saw elsewhere (market review comments about this app) that I should "uncheck" --- wait 30 seconds - and then "check" the enable item in the config menu. did that....no dice.
Frustrating :mad:
update: resolved - downloaded "no lock". Chose not to use the locking and the problem has gone away and I am still able to use Lock Bot Pro - doesn't disable that just HTC sense (I guess).
