Help lock screen ICS
ukzen
Since updating i have set lock screen with no security ,trouble is occasionally it wont unlock by touching the screen,it dims and if i hold in power button it gives all the usual options.If i press the home button a couple of times in quick succession it takes me to voice .
I just got the update yesterday and have been playing with it but have not had any problems yet. Will let you know if I do though.
Hi, I have a few minor bugs now and again but overall I am happy with the ICS update.
If you press the home button twice you will get voice, its programmed to do that, I think you have to 'swipe' the screen to unlock, its easy sometimes to swipe one way then back, not realising you have locked it again, if thats the case, you will get used to it.
touching the screen in any way does nothing,but the physical buttons work,happened again today,rebooted and it was fine.Not a major just a pain.
