Lock screen ok button disable
fascinated
Is there any way to use the pin lock without having to ok after you enter your pin?
So you would just enter your pin and the screen would unlock after the last number is entered.
No :). That would essentially tell anyone who messes with the phone when they got the code right. They wouldn't have to worry about using up perm-lock tries either.
There is an app I saw and can't remember the name, that will bypass the ok, but you have to be careful if you change pin and change it in both places before you lock it again. Sorry couldn't find it again.
Dean
Xposed framework, but it needs a rooted phone :(
