Help Lock screen woe
alackman
I have been happily using widget locker with an invisible slider used as my security. Recently I tried a new tasker profile that needed me to use the pattern unlock. There seemed no point continuing to use widget locker in the way that I was so I temporarily removed it and went to the sense unlock screen. I don't like the sense lockscreen, especially how after unlocking it, I then have to input a security pattern to get into the phone. I know I can turn off the security, but I kind if feel that's the important bit. Obviously this is a pain and I would ideally like just the one, which of course would be the security pattern.
So my two questions are
1 is there a way, without root to disable the sense unlock screen but maintaining the security pattern.
2 alternitively and ideally, is there a way to use widget locker only but including a security pattern within it that will register failed attempts (i need this bit for the tadker profile to work)
