Lock Screen
ce5ar
How do you change the lock screen sliders? Also how do you add the weather and clock widget to the lock screen?
thanks in advance.
thanks in advance.
I use Widget Locker. It allows you to place widgets on your lock screen, change wallpapers, and the lock sliders. There are other apps out there that accomplish this, but Widget Locker is typically the most recommended one, at least from what I've seen.
