Lock Screen
V
Vibrant X2
Guest
Can it be changed? can we add to it?
Inquiring minds want to know. I would like to change the clock at least.
If you are comfortable flashing files to your phone, there is a option to get:
Puzzle lock screen (the same lock screen when you get a sms)
Glass unlock (which is the stock lock screen)
Android Lock Screen
http://assets.gearlive.com/blogimages/gallery/droid-x-unboxing/motorola-droid-x-013_medium.jpg
Or the Captivate Lock Screen (which instead of swiping from side to side you swipe upwards, can't find a screenshot of it)
Or you can install widget locker and customize it like this:
http://img809.imageshack.us/img809/8554/lockscreen.png
