Root lock screens
i could never get widget locker to work properly, so i gave up on it, its paid for lol but i cant get it to work properly :(
+1 on Widgetlocker..
I have mine setup nicely, so much customization can go into it if you just play around with it.
What do you mean you can't get it to work properly. We need to figure this out for you lol. One can't go without WL
I just upgraded to GB. Has anyone had an issue w/ deleting the sliders in widgetlocker? I can't seem to delete them. They work fine, just can't delete which I used to be able to do by holding in the middle and then sliding to garbage can. I get a message that says "long press disabled in lock mode" and I have no idea how to disable that. I've looked around, but can't figure it out.
Go to the actual app in the app drawer, click it, then try. ;)
