M mike710_0 Well-Known Member Jul 16, 2013 #1 Is there anyway of locking/unlocking my galaxy s3 without having to use the power key? Can't find anything in the settings Maybe a widget to lock it or something
SebaKL Android Enthusiast Jul 16, 2013 #2 mike710_0 said: Is there anyway of locking/unlocking my galaxy s3 without having to use the power key? Can't find anything in the settings Maybe a widget to lock it or something Click to expand... You may want to look at Widgetlocker, which you can customize to your taste. It's by the same people who made Nova Launcher. You can also find plenty of ready made samples on google play, across the web and at mycolorscreen.com
w0rd Well-Known Member Jul 16, 2013 #3 I use this... https://play.google.com/store/apps/details?id=com.iml.widget.devicelock
M mike710_0 Well-Known Member Jul 16, 2013 #4 w0rd said: I use this... https://play.google.com/store/apps/details?id=com.iml.widget.devicelock Click to expand... That's just what I was looking for Thanks very much
funkylogik share the love peeps ;) Jul 16, 2013 #5 I use the home button to lock/unlock the phone. Using a combination of Nova and Screen Off And Lock app :thumbup:
