Help lockpicker for touchdown
dcooterfrog
has anybody written a lock picker app for Touchdown.
i can see the security settings value exists in sqllite in ti backup when I use explore. I can't SEE it but I saw a table for it.
I know that my company does push down the security policies every now and then but on my wm6.1 device zaynee unlock monitored the registry for the changes and set it back. I assume lock picker does the same thing
override exchange security policy
more info
is there anyway to override the security policy in touchdown
the database is windroid.db
i moved it to my sd card and looked at it
table is nd_securityconfigdata
one row per account
it looks like it has the provisioning stuff stored there
like max inactivitytimedevicelock as a col name with 1800 as a value
can someone smarter that me who can write a program (service) like zaynee unlock that monitors this key (row) and flips it back to 0
Yes, I found the same thing is SQLite. When I change it, it removes security settings until the next sync then it goes back. I would even be OK if I could change inactivitytimedevicelock from 600 to say 10,000, so it only requires a password after long periods of time between use.
