Geekyninja
I have just updated to ics on my galaxy s2!
I have also tried to find the solution to my problem but thought i would ask you experts.
When i go to display > settings I toggle the clock (show clock on lock screen) check box and nothing happens.
Same with the weather checkbox.
At the moment my lock screen is a pin password and has the clock showing.
Each toggle does not make any changes.
Whats up with that?
Anyone having same problems or have a solution. I am also using Go Launcher, but switched it and didn't make a difference.
Cheers!
Whats up with that?
Cheers!
