Lockscreen Lock
WormDoes
Android Expert
Hey Everyone,
Was wondering If anyone knew a simple way to change the lock pattern on the lockscreen? I'm not a fan of the stock lockscreen and wanted to change it, if possible. I've tried lockbot and lock 2.0 but it's really hit or miss most of the time.
Thanks
I'm not familiar with command prompts. Is there a way around this? Or a brief explination on how to use command prompts? Thanks
If your rooted you can just flash a new lock screen. Or pick a different ROM with a lock screen you like. If you're rooted that is.
I found some on XDA. I can't find any that you can flash on stock 2.1 that I'm running. Guess it's time to jump into some new ROM's if I can't find any
