Help Logging off facebook and phone drag and drop?
key_user
Hi guys, I was able to connect my phone to USB on my pc, and it shows 2 removable storages, 1 for the phone and 1 seperate for the 2gb microsd card i have inserted in. I want to add mp3's to the phone since the microsd is only 2gb's. Do I have to create a folder called music?
And how do I logg off facebook, the only option i get is refresh.
yeah you could just create a sub-folder in the media folder than cut and copy all your music to it.
To log off facebook you need go to the facebook menu where it displays the options to select news feeds,profile,friends etc and then press the button to the left of the home button, and then it gives you the option to log out.
alright i was able to log off facebook thanks
as far as the music goes i got it, so for movies I would create a folder under the media folder label it 'videos' ?
where do I put wallpapers, images, and stuff to that it shows up on the phone
it works for the microSD storage but idk about the phone
yes you could create separate folders for movies and pictures and all of your media will be automatically recognized by the media player and gallery.
