Help Lollipop 5.1
gillsman
I have a Nexus 7 2012 model running KitKat 4.4.4, I recieved the OTA for Lollipop 5.0.1 a while back but I had so many issues, so I roll back to KitKat, then a few weeks later I recieved the OTA for 5.0.2 so I tried again but there were still issues so I rolled back again to KitKat, now I hear vesion 5.1 is due soon & it's apparently claimed all the issues are fixed, my question is this ~ every time I use my nexus the 5.0.2 OTA prompts me to install but I decline, therefore if I continue to decline 5.0.2 will I not receive 5.1, in other words will I have to install 5.0.2 first in order to get the OTA for 5.1
Cheers
I think you're maybe confused as I've read that 5.0.2 is the "good" update for your tab.
I'd definitely recommend backing up your data then doing a factory reset after you receive it. That should wipe out any potential bugs and have it running beautifully
PS 5.1 isn't out yet but once you get it I think yeah you'll have to go through 5.0.1, 5.0.2 first but then again, I recommend a factory reset
[QUOTE="funkylogik, post: 6891300, member: 693753
PS 5.1 isn't out yet but once you get it I think yeah you'll have to go through 5.0.1, 5.0.2 first but then again, I recommend a factory reset[/QUOTE]
Thanks for that, 5.0.2 caused me to be unable to connect to WiFi at work, that's why I went back to Kitkat, I'll wait until 5.1 is announced then upgrade to 5.0.2 again then see if I get a 5.1 OTA
cheers
