) Running faster and smoother than it has in a long while.Have Lollipop on my Nexus 7. I did it using WUGs (just flashed and rerooted, reinstalling TWRP-- it didn't even mind that I had a Tilapia bootloader on a machine that has otherwise been converted to Grouper) Running faster and smoother than it has in a long while.
For the charging thing, the Nexus 7 (2012) is particularly sensitive to output as it's OEM charger had higher than normal output (2A). Most charges only put out 1.5A I believe. See here:
https://support.google.com/nexus/answer/2781785?hl=en
I even bought a spare on Amazon when I realized using the OEM charger from ASUS really made a huge difference on speed and effectiveness of charging. They were cheaper when I bought my spare than they are now, unfortunately.
http://www.amazon.com/ASUS-Nexus-Official-Power-Adapter/dp/B008TYKEWS/ref=sr_1_2?ie=UTF8&qid=1417280297&sr=8-2&keywords=charger nexus 7
Upshot: the output of the charging cable from the wall makes a big difference. Even worse if you are trying to use your computer to charge. Most standard charge cables have low output.
I've been having a lot of freezes and reboots since updating to 5.0 as well. I'll take a look at what's installed on it and see if I'm willing to try a factory reset at this point. If I do factory reset, I'll report back on if it helped or not.
The stock charger that comes with the 2012 Nexus 7 is rated at 2A. But as with all chargers, it will only output what the charged device draws. A 2012 Nexus 7 draws around 810mA (0.81A) when using the stock charger (I measured this with a meter).
The stock charger has the data pins on the USB connector shorted. This tells the Nexus 7 that it's safe to draw more than 500mA. Most chargers don't have the data pins shorted, since they cater to Apple, and Apple doesn't like having the data pins shorted. Without the data pins shorted, the Nexus 7 draws only 430mA when "charging" (measured with the same meter). Depending on your use, this isn't even enough to keep the battery from losing charge. In my case, using the Nexus 7 for GPS, it would lose charge when connected to a typical car charger. Replacing the charging cable with this charge-only cable fixed the problem.
Thanks. Why do I do the update FIRST and THEN factory restore?
Don't understand.
Also if I click unmount my SD card do I still need to take it out?
And if not how do I remount it?
Once I get the answers to these 3 questions am going to have a go lol
Thank you Hook that explains it for me clearly
Will be great to try when my LG g3 updates to lollipop.
Sadly the update i just did to my asus memo pad 10 me102a hasn't done much
It it didn't give me lollipop as I thought.
TOOK 2 mins and says I now have version 4.2.2
Not happy.![]()
After a few days I don't see much difference from before the factory reset. Apps still become unresponsive and eventually force close. Chrome and Tapatalk seem to do this frequently.
It's one thing to have isolated issues with devices after an update, but quite another to have widespread problems. Google really needs to step up and fix this.
For the record, my device is not, and has never been, rooted.
An old trick I remember is to clear data in the Google Services Framework app i think(?)Any tips to get the OTA update? I've been waiting (not so patiently) for almost a month now.
After all of the posts above, and in other places, you STILL want the up-date? Are you a masochist?Any tips to get the OTA update? I've been waiting (not so patiently) for almost a month now.
