Lollipop for T-mobile released
ronf119
As of 7am CST on 4/27, I am currently downloading a large software update, around 1GB.
Finally, Note 4 phones on T-mobile are being updated
Nice! Thanks for the heads up. Downloading now as well. A little over 1 GB. It should be LP. Now we can all upgrade and start the complaining threads. [emoji12]
I've downloaded the update 2 times already..once on WiFi and once on 4glte and both times when it restarts it shows a small T mobile logo and then says update failed... then it boots backs up and sends a error log update to samsung and that's it....GREAT..
I thought I would miss Xposed, but these apps make the switch to lollipop even better than I imagined. Must be rooted though...
Almost forgot... One more essential app for rooted GN4 users on Lollipop: SELinuxModeChanger. Not available on the Play store, but a simple Google search will help you locate the most recent apk. Although I have no complaints, do your research to make sure you are comfortable with it.
As you can see - it is a very simple app with one function.
