Help Looking for a fix that works...
I have my boost marquee half bricked with broken android recovery and if I hold pwr+VolUp+camera button I can get into some sort of download mode....
I ALSO have a sprint marquee with a bad ESN that someone tried to "do me a favor" and put the ESN, MEID etc from my old phone onto this one....
(NOT REPEAT NOT ASKING FOR HELP MODIFYING ESN MEID ETC)
Now I have all the parts.... how can I make one working phone.... can I take them both apart and make one phone? or is the nand part of the same board where all the phone software is stored....?
KDZ updater WILL NOT WORK even tried the offline fix.... I EVEN had the phone that boots and mostly appears as mine (phone number meid etc) hooked up and after it finished the analysis part I switched them and if I'm in download mode or whatever it is I get the update to start and go all the way to 99% then just sit there.....
Any ideas?
Stop!!!! Look I've helped a lot of people in the past and sone people just aren't made for this. Sorry but this weekend ill help you out using teamviewer. There's agood chance well be able to fix the original but
Sorry... I'm actually making progress... I think... I got my phone that was stuck on the android recovery screen to now be stuck on the "S/W Upgrade Please wait while upgrading..."
I've been banging my head so hard with this because I've always been able to fix things like this well PCs small electronics... I've soldered a JTAG on to my router to unbrick it... I have been reading and trying EVERYTHING suggested....
Anyway thanks....
i have a sprint marquee ported to boost . did the factory rest battery pull and all that. i get error code 67. can some one plz help no 3g unless i put it in airplane mode then it comes on for a sec then drops down to 1x then gone no network cant update profile without network. email me at daone3238@gmail,com thanks in advance
