Accessories Looking for a "FULL BODY" vinyl decal skin
Kaoss
Member
Ok so I'd love to get a white full body decal skin for my DX but I'd like one that covers the sides... basically the entire phone.
I saw the Carbon Fiber Phantom Skinz and it covers the sides exactly the way I'd like but doesn't cover the front like this one on Amazon> Invisibledefenders white skin
The one on amazon is perfect except the sides aren't covered like on the Phantom skinz. The more that is covered the better.
I checked out Decalgirl.com but the Amazon skin actually looks way better than theirs cut wise.
I've been searching for hours using google to no avail. I really appreciate anyone's help.
Really? These sub forums stink. Not enough traffic.
I find it hard to believe with all these full body clear skins there aren't any full body colored vinyl skins.
Oh, I guess I should retract my post...
No that's not the case at all. I appreciate your attempt at helping but clearly what I need hasn't been found yet. I don't want a gel case or a clear full body skin. I would like a white FULL body vinyl skin like the ones on decalgirl but covering everything.
Checkout Zagg Skins. I'm not sure their cover protection for all phones, but I know they have a skin that covers the entire iPhone 4 (I just ordered one for my gf).
Otherwise for the time being, you might be limited to the PhantomSkinz skin.
check out gelaskins.com they have a ton of designs, very customizable...awesome skins, got one for my macbook pro
Well I guess I give up. Gelaskins doesn't have a DX cover and it doesn't cover the entire phone...
I'm going to go with the Invisibledefenders.com
They seem to have the most coverage. I wish I could just take this bitch apart and spray paint it white.
It does have DX, you have to go to create your own design ( you can choose the artwork they have on site, just afvorite whatever artowrk you like) Full coverage? i guess im confused, why do you want the screen covered...the cover does cover the sides, back, top...there are small gaps where gaps are needed however...like battery backing...
I don't want the screen covered. Just the bottom and top. I want as much of the phone covered as possible. on the one I'm going to settle on it does cover the top and bottom screen bezels. I like that.
if you look at the regular full body kit from Phantom Skinz, it looks like it does cover the front.
i would have to think that the white carbon fiber skin covers the front.
