Tried Light Flow and it really didn't seem to work too well. Any of you find anything that allows you to control the color, flash rate, etc. of the notificationLED ? One that works with the Note 2 software.
TIA
Im using Light Manager by MC KOO. I got if from the playstore and it seems to work well for me. Granted I haven't used it extensively because I only wanted to change the color of my missed call notification, but it doesnt make my phone insane like Light Flow did.
Does this app also control reminders like light flow does?
Nice. I had been looking for a replacement for light flow but hadn't found anything yet. Just downloaded Light Manager and so far it looks like a winner. Did a quick tests of the notifications I use and everything worked perfectly. Thanks for the recommendation.
