Root Looking for best battery saving rom
D
Deleted User
Guest
Hello all, I'm currently running BAMF on mr2, and hating the battery. I can lose like 10 percent under an hour doing nothing. I have my phone underclocked in Setcpu as well. I'm looking for a ROM with great battery life. I heard ASOP roms give the best battery life, can anyone confirm? Thanks for the help!!
I can confirm it! Sense loves to use battery AOSP doesn't have a "skin" running on top of it. Also using the speedtweak.sh script will help too. If you underclock via setcpu you aren't changing the voltage, most the newer kernels you can use terminal emulator and type "su" for superuser access, of course grant it, then "speedtweak.sh" and choose an undervolt/overclock speed for the cpu so you can actually have an overclocked phone with the same or less drain on the battery.
What are some of the good stable AOSP roms out there now? CM7 and OMFB are the only ones I've heard of but I haven't been digging around much. I'm still sitting on DasBamf 1.8 with the MR1 so I'm look to flash something new and shiny soon :D
