Root Looking for Best Eris Rom
dc3324
What is the best,most stable ROM out now for the Eris? I want one that is relatively new so preferably gingerbread or something like that. Also, it can't be laggy or have bad connection like my current 2.2 ROM
I searched this ROM and found that there is CCM7 v20...should i get that instead?
I didn't know there was an update to v20. I always update when a new version comes out. Unless the dev says otherwise normally you can just do a dalvik wipe and flash over the previous version (when staying with the same rom) that way you don't have to reload anything.
