Root Looking for CM7 Call blocker
hate
Was wondering if anyone knows of good call blocker that works on CM7. Root Call Blocker Pro was perfect but on CM7 a blocked call caused phone to ring til it was rebooted. Looking for one that will stop call before 1st ring and prevent blocked callers from leaving a voicemail. Option to completely block sms or to block and save would be a plus.
And yes I know CM7 has a black list to block calls but it doesn't stop phone before ringing or stop voicemails.
I've been using Call Control from the market with pretty good success. The app will stop the unwanted calls and sms's from coming through if you properly set up the blacklist though. The only drawback is that the voice mails still can be left. There is another app named Privacy Star that works good, but it is on a trial basis. I still haven't found one that will prevent voice mails though....
Try Call Master Open Beta its made by the same people as Root Call Blocker. Its still beta ATM so its free. It might work
