nykbob
Member
Does anyone know where I can find a fully signed, odexed, rooted version of 3.29.651.5? I've searched a all over and all I found was the deodexed version. I did find this link Multiupload.com - upload your files to multiple file hosting sites! but I do not know if this is rooted.
I'm not interested in themes and after reading the below info on the xda site I decided to stay with odexed versions.
I intend on using ROM Manager so the process should be very easy.
Thanks in advance for the help.
"Q - What is the advantage? Isn't the odexed version just an "un-themable" version of the de-odexed?
A - when a ROM is deodexed, a lot it's not resigned correctly... pre-installed apps like sprint voicemail/tv/nascar, google maps, flash, etc won't update correctly. will need to flash updates for those apps... PITA. Odex everything updates normally... I also dont use themes, so no need for an deodexed version."
I want to stay with a rooted stock so I do not have to wipe as was told to me from a post that said, "You don't need to backup/restore your apps and settings if you're going from rooted stock to rooted stock update."A - when a ROM is deodexed, a lot it's not resigned correctly... pre-installed apps like sprint voicemail/tv/nascar, google maps, flash, etc won't update correctly. will need to flash updates for those apps... PITA. Odex everything updates normally... I also dont use themes, so no need for an deodexed version."
