Looking for rubberized 1-piece Droid case
(G)
Android Expert
I'm looking for a one-piece rubberized case for my Moto Droid. I don't want to be able to open the keyboard, so the case would just fit around the whole body.
I run, and the only time the case would be used was when I was running, just to act as protection if it (or I) should hit the ground. Soon as I get home, the case comes off.
Does anyone make one?
I have been looking for the same thing because i dont use the hysical keyboard too much. I know someone on the forums was selling some carbon fiber 1 piece cases but I think they were ~$60
Not sure.....but would this help?
Water proof means air proof - and using custom ROMs with OC'd kernels, this makes for a bad combination.
I think I found a silicon case that covers the droid and wont let you open the keyboard. I rarely use the physical keyboard and want to protect the phone. I have been looking for hours and I hope it is the one. It comes in a few colors too.
by looking at the pictures in the ad on ebay that is still going to allow phone to slide open...I am looking for one that does not as well
Look at this one, It looks like it will keep the key board closed.
Where did you see this? Looks interesting.
If you look closely at the pic, though, it looks like either it's a two-piece case, or it has a seam directly down the side.
Anybody come across any two piece moto droid rubberized cases that have the slit cut out on the bottom for the mouth/chin area mic?
Thanks
I mean silicon, the soft rubber kind
I bought this case in white... it looked cool. it makes the phone fatter for sure. and well its 2 pieces that is being held together at top and bottom on a like a clear sliding grid type function. the only problem is the top piece that lays on the side of the screen is really rubber and flimsy so the rubber part moves around and going in and out of pocket it moves sometimes or comes half off...
it was like 5 bucks i think.. get what you paid for :p
