Root Looking for some help
OK, so I have 2 problems that I am hoping someone good with computer stuff can help me out with.
I have a Samsung Moment that is roted and running Amstel 2.0. When I installed it on my phone (did a flash back first using the "modified" updater we use to root) my problem is I don't have Sprint Nav anymore.
I have gotten the app, put it in the apps file in the zip and re flashed the phone (back to the modified installer then with Amstel 2.0) I have to use an ES File explorer to install Sprint Nav, once it installs it works fine no problems, but as soon as I reboot it needs to be reinstalled.
Also, I have some apps that I cannot install it just says "application not installed"
Can some one help me out in simple english? I am guessing it has to do with permissions, but I don't know enough about them to play with them.
Also, my wife's phone is the same everything, but her nav stays put on a reboot.
I did check first and both permissions are set to the same
User > read& Write are checked
Group> Read is checked
Others>Read is checked
Any help would be greatly appreciated
Thank you
