Root looking for stable build
Logos
just purchased a marquee for boost (haven't updated). Is there a stable build that will allow for overclocking? if so, what rom/ program should I use?
edit: lg-lg855
ver. 2.3.4
ker. 2.6.35.7
sw ver. zv3
I dl'd the AIO and installed the drivers. dbl clicked the .bat file and clicked run. after choosing option 1 (root), it gives a message that deamon has started, however, it won't recognize the device
wat do?
wat do?
had the same problem a while back, just reinstall the drivers on your computer and retry running the .bat file. :vollkommenauf:
tried it but nogo. also, what is meant by select "usb internet connection" in usb mode?
edit: charge only...derp
