I'm on 3 using froyoand cannot turn on 3g has anyone any ideas or fixes.
I'm using switch pro widget which maybe causing the issue.
I'm on 3 and have the same problem, have rebooted several time but it makes no difference.
Rebooting made no difference for me.
Wonder if its an apn problem with switchpro widget.
Had the same issue right after the update and noticed my APNs were reset to default. I had to re-enter the proper settings to get 3g to work again.
First post on the forum, hopefully a useful one. I had the same problem on 3 but figured it out....
Go to Settings, then Wireless & Networks, then Mobile Networks (set options), then Access Point Names.
There should be a 3 (three.co.uk) with a white circle. Click on that and it should work.
