Help Lost 3G Connection
odojoe
Is anyone having the same issue? I used to be able to get a 3G connection about half the time at home and most of the time at other places. Lately I can only get 1G. It is not due to throttling as I just started a new month. I have also tried using and turning off airplane mode and going to mobile networks and turning off and then on data enabled.
The result is the same using CM7 or CM9 v0.6.10.3.
