lost bluetooth connection with wits a81
I got my Wits last week and flashed it with 1208. I then installed CoPilot and to help running it, I purchased a Holux M-1000 (GPS receiver). I worked well for one day. I installed a widget to disable bluetooth (I am new to this so I install all kinds of stuff LOL) and bluetooth turned black and never came back. Do I have to reflash... If so, will I loose what's on my MID (not my sd card)?
Thanks for your help
I also lost bluetooth after installing a bluetooth toggle widget; also installed an airplane mode widget. Don't know which one did it but Bluetooth appears grayed out in Settings and goes black when I click to activate it. I have uninstalled the wigets and pulled the battery for a soft reset, but nothing works.
Both the Wits and my Macbook pro found each other before this.
All of this started when I checked "Battery use" under "About MID" in Settings and it said 70% of my battery use was "cell standby" so I thought I would try turning off the radios (WiFi, Bluetooth, GPS) to see which one was being read as a cell phone by the device.
I installed the app Mini Info, which is really quite useful for giving basic information and a set of toggle switches. I toggled off airplane mode and toggled on blutooth several times and finally bluetooth was activated again.
Don't know exactly why this happened, but I hope it works for others.
