Lost Icon
CSRuff
My Eris has lost its "Mobile" icon that switches it on and off .. I can't seem to find it to replace it on the screen. Where does that icon reside? Thanks
If you either long-press where you want it to be, or just click the "+" on the bottom-right of the dock, a menu will come up asking what you want to add. Choose "HTC Widgets", then "Settings". You should see "Mobile network" there.
