Yup, I usually update from stock recovery. What happens is the radio is the last partition update (it will say updating lte) and then give the error I posted earlier. Once I reboot it will be that update (like .893) but without the lte radio.Just found this. It says it I'll fix 3g/ 4g and some other stuff. radio issue
I don't think that a recovery will work because they don't change basebands or kernels. Have you tried put the ota on your SD card ad flashing it from stock recovery.
