Root Lost my 3G...
Anthony2816
(Not sure whether to post this here or under Support and Troubleshooting, but since I'm rooted with Superclean 9.2, I'll ask here)
Yesterday my 3G connection vanished. Can only access the internet via wi-fi, and the little 3G symbol in the notification bar is gone. Rebooting with battery removal didn't help.
I don't see anywhere to toggle the 3G under Settings. I have an app called Quick Settings that does have a separate on/off button for 3G, but the button is now grayed out in the off setting, and it's displaying "No APN configured".
Since I'm rooted I figured I'd try here prior to dealing with Verizon tech support.
Ah, solved it. I long-pressed the power button, and was able to turn the mobile data back on from the option menu there.
